Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
MLAB physical size for Stratix V
could you please confirm which is the actual physical size of an MLAB?
Is there any ratio/scale between an MLAB in the floorplan view and the actual physical size of an MLAB in the die?
Highlighted
This isn't published, and no there's no real scale correlation between the physical size and the floorplanner view. Why are you asking the question? (If I knew, perhaps I could point to other information that would help.)
