21615 Discussions
Makefile:200:*** target pattern contains no '%'. Stop
Now i trying to build the preloader from within the Embedded Command Shell, when I insert the command of "make", it come out error say it "Makefile:200:*** target pattern contains no '%'. Stop." even i install the ARM DS-5 Altera Edition Toolkit, still cant figure out the problem yet.
I use the Quartus web version 13.0 and follow the SoC_SW_Lab_13.0 pdf tutorial available from the Arrow website.
Anyone have try it or experience the same problem b4? cant share the solution here? thanks very much!!
You need to find line 200 of the relevant Makefile.
A guess - make sure there are no spaces in any of the directory and file names.
--- Quote Start ---
--- Quote End ---
Thanks for your reply. The problem was solved.
Solution I used is install a new embedded (13.0sp1) and run the embedded command shell, then after type "make" command , everything was works fine as expected.
