Programmable Devices
20758 Discussions
Max V CPLD Pull up for pins
I am working on MAX V 5M2210ZF324C5 device for my current project.
I require some of the pins to be pulled up as this wasnt taken care in schematics.
Is this possible for the present device? Please help.
Naga Kiran
Do a search for "Programmable Pull-Up Resistor" in "MAX V Device Handbook".
Yes. MAX V has programmable pull-ups. Enable/disable it under the 'Weak Pull-Up Resistor' column in the Pin Planner.
Note:
--- Quote Start ---
The programmable pull-up resistor is active during power-up, ISP, and if the device is unprogrammed.
--- Quote End ---
Cheers,
Alex
Yingda
Hi, Alex:
    I can't find 'Weak Pull-Up Resistor' column in the Pin Planner. Note, I'm using Quartus Prime Lite 20.1.0.
                 Thanks!
