Programmable Devices
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
18638 Discussions
Max10 10m25 dual supply; jtag volatge
Honored Contributor I
I'm working on a schematic with a 10M25DAF256I7G.
I'm going to power the FPGa with supply scheme as stated on Pin Connection Guide Line page 20:
VCC: 1.2V
VCCINT: 1.2V
VCCD_PLL: 1.2V
VCCA:2.5V
VCCA_ADC:2.5V
VCCIO:3.3V
I have a problem to understand the JTAG pull-up voltage.
As stated on Pin Connection Guide Line: "for configuration voltage of 2.5v, 3.0v or 3.3v, connect this pin through a 10kohm resistor to 2.5v (vccio bank 1 b) to prevent voltage overshoot..."
But my VCCIO is 3.3V for all banks. Why it says 2.5V?
Furthermore in the MAX10 Configuration User guide on page 3-3 the pull resistor are at VCCIO Bank 1B with clamp diode. So i think i can pull-up to 3.3V.
My question is:
If i use a configuration scheme as stated on page 20 of the Pin Connection Guide Line, how do i have to connect the jtag pull-up resistor for JTAG signals? Is it 2.5V or 3.3V with diode as stated in the Connection guide line?
Yes, you can connect the pull-ups to 3.3V.
Refer to the 'max 10 fpga configuration user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/max-10/ug_m10_config.p...)', and figure 3-1 on page 3-3. Pull-ups are tied to VCCIO of bank 1 or 1B, depending on device.
Cheers,
Alex
