21602 Discussions
Max10: internal reference voltage to output pin?
fogl
Hello everybody,
I am looking for a way to conect the Max10 internal reference voltage to some output pin. Can this be done?
Klemen
YuanLi_S_Intel
We have Reference Voltage Pin (VREF) available in MAX10. However, it is meant for some I/O Bank that requires reference voltage for input operation.
fogl
Thank you for your reply. Maybe my question was a bit vague.
I would like to output the internal Vref voltage to be accessed by some external cicuit.
YuanLi_S_Intel
It is not possible as the vref input pin is used for IO buffer. May i know what is the reason to ouput vref voltage to external device?
fogl
Just to use 2.5V reference voltage for the OpAmp input.
YuanLi_S_Intel
If it so, i would suggest to use 1 of the I/O pin to supply a constant 2.5V to the OpAmp input.
