21609 Discussions
Memory test failure
Amay
We met the high failure issue of 1SG280HN2F43E2VG on functional test, failure is 1.42% (4/280), DC is 2205.
below is test error information:
Error Message: TS MP Memory Diag MMC25.vi.ProxyCaller -> TS MP Memory Diag MMC25.vi: Timeout occurred while waiting for memory devices to initialize. Last state was: { "object": { "devices": { "32-bit": { "BIST Status": "Idle", "Device": "DDR4 32-bit: U12, U13", "Init State": [ "PLL Locked", "Initialized", "Calibrated" ], "status": "OK" }, "64-bit": { "BIST Status": "Idle", "Device": "DDR4 64-bit: U8, U9, U10, U11", "Init State": [ "Not Ready", "Calibration Failed", "PLL Locked", "Initialized" ], "status": "ERROR: S_tronDiag_CAL_FAILED" }, "8-bit": { "BIST Status": "Idle", "Device": "DDR4 8-bit: U5", "Init State": [ "PLL Locked", "Initialized", "Calibrated" ], "status": "OK" }, "DIMM": { "BIST Status": "Idle", "Device": "DDR4 DIMM: J14", "Init State": [ "PLL Locked", "Initialized", "Calibrated" ], "status": "OK" } }, "status": "ERROR: S_tronDiag_CAL_FAILED" } } [Error Code: 5000]
Now we have ready 4pcs samples and need your help to process analysis, thanks!
AdzimZM_Intel
Thank you for submitting your question in Intel Community.
I'm Adzim, application engineer will assist you in this forum.
I'm not familiar with the error message that you have shown.
Does it generated from your tools/scripts?
Regarding to the error message, it's indicate that the memory interface is failing calibration process.
Do you have any software and hardware information regarding to your test such as IP information or board information?
May I know what is the process analysis that you mean in your last sentence?
So far all 4 boards is failing with same error?
Adzim
AdzimZM_Intel
As we do not receive any response from you on the previous reply that we have provided, I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Amay
We had contacted to our end customer, but they also cannot provide more detail failure information. And also cannot confirm whether is design issue. Our Flex want to Intel to check and confirm this part is good. then We can told the end customer that is their design issue.
AdzimZM_Intel
Hi Amay,
From your latest comment in this case:
"We have seen multiple failures of the DDR4 Memory calibration which are not fixed by swapping memory chips and which are fixed by swapping the FPGA. Is it possible to get failure analysis done on these chips to see if the timing and drive strength are meeting spec?"
I would instruct you to file a ticket for FACR on FPGA device either through Intel Premier Support or Intel Community.
Please state out the observation and reports that you have to help on FACR process.
As this issue is continue to FACR process, I will close this case.
Adzim
