We are having DK-SOC-1SSX-H-D development kit with us. Which supports Mini-LVDS interface. Can someone let us know, using this technology what is the maximum distance can be supported between driver and receiver.
Sanjeev
Hello Sanjeev,
We don’t have the distance PCB trace spec.
The PCB lose would be different depends on the PCB material, PCB route parameters, etc.
The only method to evaluate the PCB distance, would be simulation.
regards,
Aqid
Hi Aqid,
Thanks for the info. However is there a limitation by protocol itself such as for LVDS, distance can range from few inches to 10Meter?
Sanjeev
Do you have any more questions on this?
there's no specific limitation "by protocol". You'll however experience data rate depending signal attenuation and waveform distortion. Presuming impedance matched and correctly terminated differential cable, you can achieve 10 m distance for 100 to 200 MBPS. The other possible limitation is common mode noise and voltage offset in case of inter-instrument communication. Consider that standard network interfaces like Ethernet use transformer coupling to get rid of common noise.
Hi Sanjeev,
Do you have any more questions or help needed?
Not at this point of time.
Thank you.
Sanjeev
Thank you for your confirmation, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
