21339 Discussions
Minimum freq of SERDES megafunction in Arria II GX
Can anyone give me guidance as to the minimum frequency of operation of the SERDES megafunction (ALTLVDS) for the Arria II GX device?
Pete
The minimum and maximum specification depends on the clock source (for example, PLL and clock pin) and the clock routing resource you
use (global, regional, or local).
You could implement your design in Quartus II. After compilation, run simulation n timing analysis if your design could meet the device requirement.
ChewHow,
Thanks! I'll give it a whirl.
