21619 Discussions
Multiple windows opening in Modelsim Student version
Hii...I am using MODELSIM student edition 10.4a. Every time I am trying to open a .vhd file within the program from project window, multiple
windows open... how do i fix it? I have tried to restart the program and reboot the pc as well but nothing worked. Also I have tried to reinstall the MODELSIM, which also didnt work. Please help me with this.
Thanks and regards!
I allso had this issue. Which OS do you use? Sadly i did not find solution how to fix this. Only thing that worked for me to avoid multiple windows opening is every time I open Modelsim I change default program which opens .vhdl files to notepad and back to Modelsim. For me it works until modelsim is closed.
--- Quote Start ---
--- Quote End ---
I am using windows 8. After deleting all registry files and again installing MODELSIM worked for me.
