NEEK VGA Module
[attachment=194:NEEK_VGA.zip][attachment=194:NEEK_VGA.zip][attachment=194:NEEK_V
GA.zip]neek_rgb_vga.vhd is the VHDL module.
The module accepts parallel RGB plus HV syncs with DATA Enable and a clock that is three (3) times the RGB pixel rate and outputs a NEEK VGA TDM data stream with syncs and enables.
The ZIP contains a QuartusII Archive and will build a small test example of an instantiation of the "NEEK_RGB_VGA" module.
Save off the SOF file before you rebuild so that you can see what it does, before you try to build it.
*** Built with QuartusII v9.0 (sp1) and uses the Test Pattern Generator and Clocked Video Output from the Video IP to generate a video stream.
(A copy of this example project is in the Hardware Projects group, also)
*** Note: Archive missing .SOPC file (Added to ZIP on 7/17/09 )
