Hi All!
I've a problem with Nios SPI communication. I studied "Embedded Peripherals IP User Guide" but I didn't understand how to use alt_avalon_spi_command() function. I understood that an Avalon-MM master peripheral controls and communicates with the SPI core via six 32-bitregisters. So I searched more examples on web but I only found this: //------------------------------------ MAIN ------------------------------------------------------------ int main(void){ void send(alt_u16 write); alt_u16 receive(); alt_u16 wrdata=0xabcd; alt_u16 rddata; IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(SPI_BASE, 1); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); while(1){ send(wrdata); rddata=receive(); } return 0; } //-------------------------------------- SEND ------------------------------------------------------------------------- void send(alt_u16 write){ alt_u32 status; alt_u16 data; IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0x0400); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do{ status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0)&&(status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , write); data=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do{ status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0); } //----------------------------------- RECEIVE -------------------------------------------------------------------------- alt_u16 receive(){ alt_u16 data; alt_u32 status; IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0x0400); IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do{ status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 ) && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , 0x00); data=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE); do{ status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE); } while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0); IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0); return data; } The question is "What's the difference between alt_avalon_spi_command() and IOWR_ALTERA_AVALON_SPI_TXDATA() to transmit a data via SPI"? Thank you all :)Link Copied
The difference should be clear from the description in the user guide? alt_avalon_spi_command() performs the sequence of actions described in the manual, while IOWR_ALTERA_AVALON_SPI_TXDATA() just writes the TXDATA register.
You can read the source to the alt_avalon_spi_command() function and see how it uses IOWR_ALTERA_AVALON_SPI_TXDATA() and everything else that it does to gain better understanding. There is also an example use of the function here: http://www.alterawiki.com/wiki/spi_core- Mark as New
Thank you, you were so clear. I have another question please. What have I do to set NIOS in slave mode in SPI communication? I explane my problem. I have to load Cyclone V firmware into an external EPCQ128 with a microcontroller that communicates with NIOS via SPI. And so, I need to set my microcontroller as master, and NIOS as slave in SPI communication.
I tried to write a simple code section in C language to make SPI communication, with NIOS as slave. Can you check if my code is good please?
static void spi_rx_isr(void* isr_context); static void spi_rx_isr(void* isr_context){ IOWR_ALTERA_AVALON_SPI_STATUS(SPI_SLAVE_BASE, 0x0); } int ret; int status; alt_u16 rddata; //this registers slave IRQ with NIOS ret = alt_iic_isr_register(SPI_SLAVE_IRQ_INTERRUPT_CONTROLLER_ID,SPI_SLAVE_IRQ,spi_rx_isr,(void *)spi_command_string_tx,0x0); //check if slave status is good do{ status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_SLAVE_BASE); } while ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0); //copy received byte into rddata variable rddata = IORD_ALTERA_AVALON_SPI_RXDATA(SPI_SLAVE_BASE); //set slave IRQ to enable a new byte receiving IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_SLAVE_BASE, ALTERA_AVALON_SPI_CONTROL_SSO_MSK | ALTERA_AVALON_SPI_CONTROL_IRRDY_MSK);- Mark as New
HI fmv,
i'm facing the same problems that you had. I tried both codes you have proposed but i still have several problems to obtain data and retransmitt data back to the Master defined as a microcontroller. I was wondering if you could provide me the entire code that you've used in order to solve the problem or some advices to adopt. Thanks- Subscribe to RSS Feed
