20704 Discussions
NIOS II SPI communication
Hi All!
I've a problem with Nios SPI communication. I studied "Embedded Peripherals IP User Guide" but I didn't understand how to use alt_avalon_spi_command() function. I understood that an Avalon-MM master peripheral controls and communicates with the SPI core via six 32-bitregisters. So I searched more examples on web but I only found this:
//------------------------------------ MAIN ------------------------------------------------------------
int main(void){
void send(alt_u16 write);
alt_u16 receive();
alt_u16 wrdata=0xabcd;
alt_u16 rddata;
IOWR_ALTERA_AVALON_SPI_SLAVE_SEL(SPI_BASE, 1);
IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE);
while(1){
send(wrdata);
rddata=receive();
return 0;
//-------------------------------------- SEND -------------------------------------------------------------------------
void send(alt_u16 write){
alt_u32 status;
alt_u16 data;
IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0x0400);
do{
status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_BASE);
while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0)&&(status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0);
IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , write);
data=IORD_ALTERA_AVALON_SPI_RXDATA(SPI_BASE);
do{
while ((status & ALTERA_AVALON_SPI_STATUS_TMT_MSK) == 0);
IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_BASE, 0);
//----------------------------------- RECEIVE --------------------------------------------------------------------------
alt_u16 receive(){
alt_u16 data;
alt_u32 status;
do{
while (((status & ALTERA_AVALON_SPI_STATUS_TRDY_MSK) == 0 ) && (status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0);
IOWR_ALTERA_AVALON_SPI_TXDATA(SPI_BASE , 0x00);
do{
return data;
The question is "What's the difference between alt_avalon_spi_command() and IOWR_ALTERA_AVALON_SPI_TXDATA() to transmit a data via SPI"?
Thank you all :)
The difference should be clear from the description in the user guide? alt_avalon_spi_command() performs the sequence of actions described in the manual, while IOWR_ALTERA_AVALON_SPI_TXDATA() just writes the TXDATA register.
You can read the source to the alt_avalon_spi_command() function and see how it uses IOWR_ALTERA_AVALON_SPI_TXDATA() and everything else that it does to gain better understanding.
There is also an example use of the function here:
http://www.alterawiki.com/wiki/spi_core
Thank you, you were so clear. I have another question please. What have I do to set NIOS in slave mode in SPI communication? I explane my problem. I have to load Cyclone V firmware into an external EPCQ128 with a microcontroller that communicates with NIOS via SPI. And so, I need to set my microcontroller as master, and NIOS as slave in SPI communication.
I tried to write a simple code section in C language to make SPI communication, with NIOS as slave. Can you check if my code is good please?
static void spi_rx_isr(void* isr_context);
static void spi_rx_isr(void* isr_context){
IOWR_ALTERA_AVALON_SPI_STATUS(SPI_SLAVE_BASE, 0x0);
int ret;
int status;
alt_u16 rddata;
//this registers slave IRQ with NIOS
ret = alt_iic_isr_register(SPI_SLAVE_IRQ_INTERRUPT_CONTROLLER_ID,SPI_SLAVE_IRQ,spi_rx_isr,(void *)spi_command_string_tx,0x0);
//check if slave status is good
do{
status = IORD_ALTERA_AVALON_SPI_STATUS(SPI_SLAVE_BASE);
while ((status & ALTERA_AVALON_SPI_STATUS_RRDY_MSK) == 0);
//copy received byte into rddata variable
rddata = IORD_ALTERA_AVALON_SPI_RXDATA(SPI_SLAVE_BASE);
//set slave IRQ to enable a new byte receiving
IOWR_ALTERA_AVALON_SPI_CONTROL(SPI_SLAVE_BASE, ALTERA_AVALON_SPI_CONTROL_SSO_MSK | ALTERA_AVALON_SPI_CONTROL_IRRDY_MSK);
HI fmv,
i'm facing the same problems that you had. I tried both codes you have proposed but i still have several problems to obtain data and retransmitt data back to the Master defined as a microcontroller. I was wondering if you could provide me the entire code that you've used in order to solve the problem or some advices to adopt.
