Have spent several days now searching and reading and think I am nearly there... but not quite. I am using the NIOS II core with SOPC builder. I use Quartus II for the FPGA image. This is a project I have inherited which kept the FPGA image in a ECPS64 and the software image in CFI. I have combined the two and keep them in the EPCS64. Works OK. I have been trying to get the remote update controller to work. I have put it into the core via SOPC and can read and write its registers via NIOS. I can also make it do a reconfig but it always seems to use the factory image. Has any one got a working example using the Cyclone III and NIOS II?
I use the following to read 2 of the registers... ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x4); ParamValue = IORD( REMOTE_UPDATE_CYCLONEIII_0_BASE, 0x0); After power on both registers read 0. After reconfig command, register 0 = 1 and register 4 = 8 Any ideas please? Brain is starting to hurt!Link Copied
- « Previous
- Next »
You must enable the watchdog feature in the factory software before triggering the reconfiguration; then you clear it in the application software. This way if fpga is configured but software doesn't start, the watchdog would reset back to the factory image.
Did it, enable the watchdog in the factory sof but now I can't boot on the application image I always stay in the factory image.
I modified 0x5 by ((0x1FFFFFFF) >>17) to obtain upper 12 bits of 29-bit watchdog timeout value, ok now it boots on
my application software, but after awhile I go back to the factory software while I disabled the in the app code like in the code above.- Mark as New
Thanks for sharing.
factory code :
IOWR_RU_Watchdog_Timeout_Value(0x1FFF0000 >> 17); IOWR_RU_Force_Osc_Int(0x1); // Force the internal oscillator as startup state machine IOWR_RU_Early_Conf_Done(0x1); // Force Early CONF_DONE what do I have to write in my app code to prevent my app code to go back to the fac mode while watchdog was disabled ?- Mark as New
It's like if the IOWR from my app code didn't act...
- « Previous
- Next »
