Hi there,
i startet now my first nios application. I programmed the DE0 Board and now I want to run the counter-template from NIOS II. But it dont works (onchip memory overflows). What can I make ? Greetings DE0Link Copied
I use the NIOS/f and take the Flash with a higher memory - now it works
If you are adding print statements into your design, you might consider using the small C library option in the BSP. It will restrict some of the things you can do, but it can squeeze a fair amount more into on-chip memory otherwise.
Hi, I'm new to NiosII. I get on-chip memory overlappings when I build the C application. My system includes RS232 uart, Pio, SPI interface and 512K SRAM controller. I'd like to use the SRAM but I don't know how to set the program memory in my NiosII IDE. I remember that the Altera Monitor Program gives the opportunity to select the memory during the new project wizard...
Can you help me? Thank you a lot
