Hi there,
How do I determine the number of single ended digital input/outputs of the FPGA EPCQ4ASI8N EPCQ-A? cannot find the number in the datasheet.
EPCQ4A is no FPGA, it's a serial flash used as FPGA configuration device. It has two inputs, and four bidirectional I/Os when operated in ASx4 mode, but that's probably not what you are asking for.
Hi Ibrahim,
Thank you for reaching out Intel FPGA Community.
Yes, EPCQ4ASI8N is not an FPGA, but it is a serial configuration device for FPGA.
As refer to the datasheet, this device, specifically EPCQ4A, is only supports AS x1 only and not ASx4 configuration mode.
Hence, based on the device's pin information, they only have two I/O pins (DATA0, DATA1). You can refer to below link for more information:
Aqid
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
