Hi Team,
We are using MAX® 10 Field Programmable Gate Array (10M08SAE144C8G) in our design and this fpga is out of stock. We have found Intel® Cyclone® 10 10CL010 FPGA in the portal where the spec is similar to the MAX 10 FPGA. Data sheet is not provided in the portal. Can you provide the datasheet.
Along with this can you please suggest the drop and replaceable part for MAX® 10 Field Programmable Gate Array (10M08SAE144C8G).
Chandana.
I apologize that you are seeing this stock issue. Rest assure I am here to help you.
You can refer to our catalog to compare our devices. Asides from that, I will also include Intel® Cyclone® 10 Device Datasheet below.
Resources:
2. Intel® Cyclone® 10 LP Device Datasheet
3. Intel® Cyclone® 10 GX Device Datasheet
Thank you.
Thanks for the response.
Could you please share pinout for Intel® Cyclone® 10 10CL010
Please refer to this link: https://www.intel.com/content/www/us/en/support/programmable/support-resources/devices/lit-dp.html
Thank you
