Programmable Devices
21471 Discussions
Need RMA#'s for 7 FPGS - ALL HAVE FAILURE TO GROUND PROBLEMS 5SGXEABH40C2NGA - 1 PIECE 10AS066N3F40E2SG - 6 PIECE
SLitc1
Zawani_M_Intel
Dear Sharon,
Please tell me the story of this part, how you discovered it have failure to ground?How the it was measured, and such as that. Also, did you observe a functional failure in the operation of the devices?
* Each case must ONLY have one OPN.
Wani
SLitc1
Good Morning, Lets start with these 4 first: 10AS066N3F40E2SG - 4 parts with date code 1913 failed at testing scan. Rework activities (x-ray, reflow) showed no faults in the solder application. Replaced all 4 parts with new ones and all 4 boards passed. Suspect faulty FPGA's. Regards, Sharon Litchfield Quality Engineer Benchmark Electronics, Inc. 100 Innovative Way Nashua, NH 03062 ph. 603-879-7066
SLitc1
Good Morning, Additional returns: 10AS066N3F40E2SG - 2 parts with date code 1901 failed at test scan, both have v-core P1V8 shorted to gnd. 5SGXEABH40C2NGA - 1 part with date code 1849 failed test scan, TP52 to GND short. Regards, Sharon Litchfield Quality Engineer Benchmark Electronics, Inc. 100 Innovative Way Nashua, NH 03062 ph. 603-879-7066
Zawani_M_Intel
Hi Sharon,
Can you confirm what pin is P1V8?
Can you confirm what pin is TP52?
Wani
SLitc1
Wani,
Please see requested data and advise on the RMA# for all 7 FPGAs.
Pins for P1V8 are:
Pins: AB14, AC14, AC16, AC17, AC19, AC21,AF18, AF19, AK19, AL21, AM18, AP17,AP22, AT21
     H20, J22, K19
     U15, U16, U17, U20, U21, U22
_____________________________________________________________________
TP52 = PV_S5CORE: Pins A1, A2, A3, A4, A5, A8, A9, A10, A11, A12,
                                            B1, B2, B3, B4, B5, B8, B9, B10, B11, B12,
                                             C1, C2, C3, C4, C9, C10, C11, C12
Sharon Litchfield
Quality Engineer
100 Innovative Way
Nashua, NH 03062
ph. 603-879-7066
Deshi_Intel
Hi Sharon,
I will be covering for Wani as she is out for maternity leave.
I will initiate private message for ease of FA support.
One thing to take note is Intel typically support FA case per FPGA product family. We don't mix failure cases from 2 different FPGA product family into same FA report.
May I proposed to use this case for 10AS066N3F40E2SG FA debug discussion while pls open another new forum case for 5SGXEABH40C2NGA FA debug ?
dlim
Deshi_Intel
Hi Sharon,
Intel has shared the FA report and Dale also has explained the FA result analysis to Benchmark.
Feel free to reach out to Dale if Benchmark still has any follow up questions.
For my side, I am setting this case to closure.
dlim
