Dear Sharon,
Please tell me the story of this part, how you discovered it have failure to ground?How the it was measured, and such as that. Also, did you observe a functional failure in the operation of the devices?
* Each case must ONLY have one OPN.
Wani
Hi Sharon,
10AS066N3F40E2SG - 2 parts with date code 1901 failed at test scan, both have v-core P1V8 shorted to gnd.
Can you confirm what pin is P1V8?
5SGXEABH40C2NGA - 1 part with date code 1849 failed test scan, TP52 to GND short.
Can you confirm what pin is TP52?
Wani
Wani,
Please see requested data and advise on the RMA# for all 7 FPGAs.
Pins for P1V8 are:
Pins: AB14, AC14, AC16, AC17, AC19, AC21,AF18, AF19, AK19, AL21, AM18, AP17,AP22, AT21
H20, J22, K19
U15, U16, U17, U20, U21, U22
_____________________________________________________________________
TP52 = PV_S5CORE: Pins A1, A2, A3, A4, A5, A8, A9, A10, A11, A12,
B1, B2, B3, B4, B5, B8, B9, B10, B11, B12,
C1, C2, C3, C4, C9, C10, C11, C12
Sharon Litchfield
Quality Engineer
Benchmark Electronics, Inc.
100 Innovative Way
Nashua, NH 03062
ph. 603-879-7066
Hi Sharon,
I will be covering for Wani as she is out for maternity leave.
I will initiate private message for ease of FA support.
One thing to take note is Intel typically support FA case per FPGA product family. We don't mix failure cases from 2 different FPGA product family into same FA report.
May I proposed to use this case for 10AS066N3F40E2SG FA debug discussion while pls open another new forum case for 5SGXEABH40C2NGA FA debug ?
dlim
Hi Sharon,
Intel has shared the FA report and Dale also has explained the FA result analysis to Benchmark.
Feel free to reach out to Dale if Benchmark still has any follow up questions.
For my side, I am setting this case to closure.
dlim
