Programmable Devices
21401 Discussions
Need help from Guru
Hey guys,
I am looking for some help in the syntax. Following is my syntax to perform a voting system.
Library IEEE;
USE IEEE.std_logic_1164.all;
Entity Gproject IS
PORT ( Se0, Se1, Se2, Se3 : IN std_logic;
Sn0, Sn1, Sn2, Sn3 : IN std_logic;
D : OUT std_logic_vector (6 downto 0);
Co : OUT std_logic;
L1, l2, L3 : OUT std_logic;
less : out std_logic;
equal : out std_logic;
greater : out std_logic);
End Gproject;
Architecture Vsystem OF Gproject IS
Component Attendance
S1, S2, Co : OUT std_logic);
END component;
Component AddSub
PORT( A, B :IN std_logic_vector(3 DOWNTO 0);
S :IN std_logic;
Co :OUT std_logic;
X :OUT std_logic_vector(3 DOWNTO 0));
END component;
Component Comparator
port( A : in std_logic_vector(3 downto 0);
B : in std_logic_vector(3 downto 0);
end component;
Component SegmentDisplay
port( W :IN std_logic_vector (3 downto 0);
D :OUT std_logic_vector (6 downto 0));
End component;
Signal at: std_logic_vector (12 downto 5);
Signal X: std_logic_vector (3 downto 0);
Begin
at(5) <= '0';
at(9) <= '0';
X(3) <= '0';
Att : Attendance PORT MAP (Se0, Se1, Se2, Se3, at(6), at(7), at(8));
Display1 : SegmentDisplay PORT MAP (at(8 downto 5), D(6 downto 0));
Vsystem : Attendance PORT MAP (Sn0, Sn1, Sn2, Sn3, at(10), at(11), at(12));
Display2 : SegmentDisplay PORT MAP (at(12 downto 9), D(6 downto 0));
Add_Sub : AddSub PORT MAP (at(8 downto 5), at (12 downto 9), '1', Co, X(3 downto 0));
Compare : Comparator PORT MAP (at(12 downto 9), X(3 downto 0), less, equal, greater);
End Vsystem;
________________________________________________________________
I got the error msg
Error (10028): Can't resolve multiple constant drivers for net "X[3]" at Gproject.vhd(52)
I do not understand and can't find where is my mistake. I hope anyone here would help me to answer my question.
you're driving X(3) to '0', but you're also driving it from the output of the addsub.
You can only do one or the other.
Your are assigning X(3) twice:
- X(3) <= '0';
- output port of AddSub component
do you guys mind telling me how should I compute the syntax for this part?
BTW... I deleted the X(3) <= '0' then tried to compile...
NOW... new problems...
Error: Node instance "H1" instantiates undefined entity "H_adder"
(H_adder is one of the component I use in the blocks)
May I know what this means?
The code that you showed doesn't have any H1 instantiation.
The most likely cause is that you forgot to declare the H_adder component in your architecture.
my problems have been solved.
thanks guys for the advices.
