Hey guys,
I am looking for some help in the syntax. Following is my syntax to perform a voting system. Library IEEE; USE IEEE.std_logic_1164.all; Entity Gproject IS PORT ( Se0, Se1, Se2, Se3 : IN std_logic; Sn0, Sn1, Sn2, Sn3 : IN std_logic; D : OUT std_logic_vector (6 downto 0); Co : OUT std_logic; L1, l2, L3 : OUT std_logic; less : out std_logic; equal : out std_logic; greater : out std_logic); End Gproject; Architecture Vsystem OF Gproject IS Component Attendance PORT ( Se0, Se1, Se2, Se3 : IN std_logic; S1, S2, Co : OUT std_logic); END component; Component AddSub PORT( A, B :IN std_logic_vector(3 DOWNTO 0); S :IN std_logic; Co :OUT std_logic; X :OUT std_logic_vector(3 DOWNTO 0)); END component; Component Comparator port( A : in std_logic_vector(3 downto 0); B : in std_logic_vector(3 downto 0); less : out std_logic; equal : out std_logic; greater : out std_logic); end component; Component SegmentDisplay port( W :IN std_logic_vector (3 downto 0); D :OUT std_logic_vector (6 downto 0)); End component; Signal at: std_logic_vector (12 downto 5); Signal X: std_logic_vector (3 downto 0); Begin at(5) <= '0'; at(9) <= '0'; X(3) <= '0'; Att : Attendance PORT MAP (Se0, Se1, Se2, Se3, at(6), at(7), at(8)); Display1 : SegmentDisplay PORT MAP (at(8 downto 5), D(6 downto 0)); Vsystem : Attendance PORT MAP (Sn0, Sn1, Sn2, Sn3, at(10), at(11), at(12)); Display2 : SegmentDisplay PORT MAP (at(12 downto 9), D(6 downto 0)); Add_Sub : AddSub PORT MAP (at(8 downto 5), at (12 downto 9), '1', Co, X(3 downto 0)); Compare : Comparator PORT MAP (at(12 downto 9), X(3 downto 0), less, equal, greater); End Vsystem; ________________________________________________________________ I got the error msg Error (10028): Can't resolve multiple constant drivers for net "X[3]" at Gproject.vhd(52) ________________________________________________________________ I do not understand and can't find where is my mistake. I hope anyone here would help me to answer my question. ThanksLink Copied
you're driving X(3) to '0', but you're also driving it from the output of the addsub.
You can only do one or the other.- Mark as New
Your are assigning X(3) twice:
- X(3) <= '0'; - output port of AddSub component- Mark as New
do you guys mind telling me how should I compute the syntax for this part?
BTW... I deleted the X(3) <= '0' then tried to compile... NOW... new problems... Error: Node instance "H1" instantiates undefined entity "H_adder" (H_adder is one of the component I use in the blocks) May I know what this means? Thanks- Mark as New
The code that you showed doesn't have any H1 instantiation.
The most likely cause is that you forgot to declare the H_adder component in your architecture.- Mark as New
my problems have been solved.
thanks guys for the advices.
