21605 Discussions
Need help with 3 bit parity generator!
I'm tasked to design a 3 bit parity generator by using VHDL code but i can't seem to get it right. Can anyone help me with this? Thanks in advance!
This is what i have done:
library ieee;
use ieee.std_logic_1164.all;
entity paritygen is
port (a, b, c : in std_logic;
odd_out, even_out : out std_logic);
end paritygen;
architecture work of paritygen is
begin
process (a, b, c)
if (a ='0', b ='0', c ='0')
then odd_out <= "0"; even_out <= "0";
else
odd_out <= ((a xor b) xor c);
even_out <= ((a xor b) xnor c);
end process;
The question:
To design a 3-bit parity generator/checker that has three data inputs (A to C) and two odd/even parity outputs (odd_out and even_out). When the number of high level input is odd, odd_out is kept HIGH and even_out output LOW. Likewise, if the number of high level input is even, even_out is kept HIGH and odd_out LOW. The design of this generator is to be written in VHDL. Produce the truth table for this generator and treat C as the MSB.
Expected simulation results is at the attached file.
True parity generator would be:
process (a, b, c)
even_out <= (not odd_out);
end process;
If you actually want both outputs low when inputs are all low, then
process (a, b, c)
if (a or b or c) then
else
odd_out <= '0';
even_out <= '0';
end if;
end process;
--- Quote Start ---
process (a, b, c)
end process;
process (a, b, c)
else
odd_out <= '0';
even_out <= '0';
end if;
end process;
--- Quote End ---
When i tried your code, it gives 4 errors when i tried to compile.
Error: tyoe of identifier "a" does not agree with its usage as boolean type
Error: tyoe of identifier "b" does not agree with its usage as boolean type
Error: tyoe of identifier "c" does not agree with its usage as boolean type :(
This will work:
library ieee; use ieee.std_logic_1164.all; entity paritygen is port (a, b, c : in std_logic; odd_out, even_out : out std_logic); end paritygen; architecture work of paritygen is begin process (a, b, c) begin if (a = '1') or (b='1') or (c='1') then odd_out <= ((a xor b) xor c); even_out <= not ((a xor b) xor c); else odd_out <= '0'; even_out <= '0'; end if; end process; end;
