21615 Discussions
Need some help with a suffix please.
CNguy26
10AX115U3F45E2SGE3 . What does the suffix "E3" designate? Its definition is not listed in the Ordering Code section of the datasheet. Those suffixes "indicate specific device options or shipment method", but the datasheet does not list what "E3" designate. Thanks for your help.
Vicky1
“E3” is merely a suffix for dedicated customer identification. There is no difference on functionality between 10AX115U3F45E2SG and 10AX115U3F45E2SGE3 . You can just ignore this suffix.
Refer the link below for "Suffixes",
https://www.intel.com/content/www/us/en/products/programmable/sample-ordering-codes.html
Vikas
CNguy26
Thanks Vikas.
You mentioned: "dedicated customer identification". Is the suffix E3 also printed on the parts?
Vicky1
Yes, It is printed and that too used for shipment method.
Since Suffixes are optional, you should ignore them.
Vikas
