Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Nest if statement in case statement
Is it customary and synthesizable to use nested 'case' statement inside the 'if' statement?
Tnx
Highlighted
Re: Nest if statement in case statement
--- Quote Start ---
Tnx
--- Quote End ---
No it is not , but it dosent make any sense why would anyone use "case" inside a "if" when you can use elsif multiple times .
for example:
Interfacing_ADC_DAC: PROCESS(sys_clk, reset_n)
BEGIN
IF reset_n = '0' THEN
ADC_data_A <= (others=>'0');
ADC_data_B <= (others=>'0');
DA <= (others=>'0');
DB <= (others=>'0');
LEDG(1 downto 0) <= (others=>'0');
-- 1st Condition -------------------
ELSIF SW(4 downto 2) = "011" THEN
LEDR(2 downto 0) <= "001";
ADC_data_A <= ADA_D;
ADC_data_B <= ADB_D;
-- DAC is connected to an Up-Counter
DA <= Count;
DB <= not(Count);
-- 2nd Condition -------------------
ELSIF SW(4 downto 2) = "010" THEN
LEDR(2 downto 0) <= "010";
-- ADC output is connected directly to DAC
DA <= ADA_D;
DB <= ADB_D;
-- 3rd Condition -------------------
ELSIF SW(4 downto 2) = "001" THEN
LEDR(2 downto 0) <= "100";
-- DAC is connected to a NOC output
DA <= nco_sin_out + OFF_set;
DB <= nco_sin_out + OFF_set;
-- 4th Condition ----------------<< FIR Filter
ELSIF SW(4 downto 2) = "101" THEN
-- ADC is connected to FIR Filetr
ast_sink_data <= ADA_D;
DA <= ast_source_data;
DB <= not(Count);
END IF;
END PROCESS;
Highlighted
Tnx for quick response.
The "No it is not" answer refers to customary or synthesizable or both of them?
Tnx
Highlighted
--- Quote Start ---
Tnx
--- Quote End ---
unfortunately I disgree with the "no..." from fpga_guru011.
The main differences are to do with priority issues. the case statement is equivalent to multiple parallel ifs.
Most of everyday code is made up of " if" or "case" inside each other.
if rising_edge(clk) then
if enable = '1' then
case ....
when ....
if...
end if;
end case;
end if;
end if;
Highlighted
--- Quote Start ---
Tnx
--- Quote End ---
There is no problems using Case inside If or If inside case. It depends what you are doing, and what you expect from the circuit.
Highlighted
Thanks to all 🙂
