20705 Discussions
New User - Licensing Error in Simulation
Hey everyone!
This is my first time using Quartus at all. I installed it on my laptop so I can do my school work at home. I was able to build a block digaram and compile it no problem but i'm getting an error for running a simulation.
Unable to checkout a license. Vsim is closing.
** Fatal: Invalid license environment. Application closing.
Unable to checkout a license. Make sure your license file environment variables are set correctly and then run 'lmutil lmdiag' to diagnose the problem.
Modelsim-Altera uses the following environment variables to check the licenses (listed in the order of preference)
1. MGLS_LICENSE_FILE
2. LM_LICENSE_FILE.
Error.
I don't know why i'm getting this error, i did some serahcing around and got the idea to request for a license? I was able to get one via email using my NIC. I added the license file to my quartus ii web edition but i'm still getting the same error.
I also found something to install these license files? called
lmgrd.exe
lmulti.exe
mgcld.exe
They open a cmd and close right away ( ran in admin as well).
Now I ran out of ideas. I'm very new so Id really appreciate it if someone gives me a solution it could be step by step processes. Thank you very much!
Which version of Quartus and Modelsim are you using? Make sure you are using the ModelSim-Altera Starter Edition (not ModelSim-Altera Edition, without the word "Starter").
edit
I'm using Version 15, since my school uses version 15. Also I downloaded modelsim starter edition since it came with the download page. http://dl.altera.com/15.0/ Even though I check my pc, it doesn't say starter edition on it but I'm positive it is since thats the only thing i've ever downloaded with it.
MGonz57
Was this ever solved? i'm having the same problem, i found this https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd06272006_61.html and below it has a link to download the license (https://www.altera.com/support/software/download/daemons/dnl-lic_daemons.jsp) but it leads into a "no resource found" page
