Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Nios II Exception Vector
Hi everyone,
i have a question about the Nios II exception vector.
Why is the default offset of the general exception vector 0x20 ?
The Nios II handbook writes:
Offset allows you to specify the location of the exception vector relative
to the memory module’s base address
Can i also select 0x00 in place of 0x20 for the offset ?
regards,
Nicolas
