21324 Discussions
Nios II Interval Timer Core Question
I am new on Nios II design, from Altera reference books I face a problems about the Timeout Period of Interval Timer Core. The function of Timeout Period is work as frequency divider of system clock?
Example:
My system(CPU) clock is 10ns, then on the Timeout Period setting I set it to 1us, therefore is it the system now will become 1us? or the timeout period output is just for internal timer interrupt?
Hope my question is clear....
Thanks !
The timer is only a timer. It is not a frequency divider for the system clock. The timeout period specifies how often the interrupt will occur.
Frequency division can be performed with a PLL or by writing your own clock divider.
Jake
Thank You Jake!
