21597 Discussions
No clocks defined in design / Minimal verilog only example
I've been stuck at this for two days.
First of I'm very new to Altera so this is probably something very
simple but I just can't figure/google this one out.
I've set up a simple project that compiles fine, except I get this "No clocks defined in design" error
and thus cannot get the Fmax for my trial design.
Obviously somehow the compiler does not understand that there is a clock used in
my Verilog code or something, but I cannot figure out what to do.
My verilog is like this:
module correlator(
input clk,
input sys_rst
<snip>
always @(posedge clk) begin
<snip>
This is my .qsf
set_global_assignment -name FAMILY "Arria 10"
set_global_assignment -name DEVICE 10AS066N3F40E2SG# set_global_assignment -name FAMILY "Cyclone 10 GX"
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 17.1.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "14:57:02 JANUARY 17, 2018"
set_global_assignment -name LAST_QUARTUS_VERSION "17.1.0 Pro Edition"
set_global_assignment -name TOP_LEVEL_ENTITY correlator
set_location_assignment PIN_G1 -to clk
set_global_assignment -name FMAX_REQUIREMENT "100 MHz" -section_id clocka
set_global_assignment -name DUTY_CYCLE 50 -section_id clocka
set_instance_assignment -name CLOCK_SETTINGS clocka -to clk
set_global_assignment -name BASED_ON_CLOCK_SETTINGS clocka -section_id clockb
set_global_assignment -name MULTIPLY_BASE_CLOCK_PERIOD_BY 1 -section_id clockb
set_global_assignment -name DIVIDE_BASE_CLOCK_PERIOD_BY 2 -section_id clockb
set_global_assignment -name DUTY_CYCLE 50 -section_id clockb
set_global_assignment -name OFFSET_FROM_BASE_CLOCK "500 ps" -section_id clockb
set_global_assignment -name INVERT_BASE_CLOCK OFF -section_id clockb
set_instance_assignment -name CLOCK_SETTINGS clockb -to clkx2
set_instance_assignment -name MULTICYCLE 2 -from clk -to clkx2
In my .sdc I have:
create_clock -name {clk} -period 1.000 -waveform { 0.000 0.500 } [get_ports {clk}]
create_clock -name {clkx2} -period 1.000 -waveform { 0.000 0.500 } [get_ports {clkx2}]
I've copied those from the 'filtref' example from Quartus installation
and that project compiles fine and produces Fmax, but that project
has toplevel as schematic entry and I want/need Verilog/textfile only solution.
I've tried to find a complete example project that would be Verilog with
text only files but have not found one ... so a pointer would be highly
appreciated.
But the main question is how do I make Quartus recognize my clock?
wbr Kusti
check the warnings and ensure it hasnt removed all of your logic. This can often happen for several reasons:
- Clock not connected, or stuck at 1/0
- Reset always asserted
- Input logic stuck at specific value, causing design to be optimised awa
- Design having no effect on any outputs.
If you have no outputs in the design that can connect to pins, then the whole design will be optimised away.
Thank you!
--- Quote Start ---
--- Quote End ---
Thanks, I was thinking along those lines. But this is where I need some hand holding.
Your write "If you have no outputs in the design that can connect to pins", this raises the question
how to ensure that "outputs can connect to pins" ?
Looking at my code I see that I actually have no outputs out of the module so indeed this can be the problem.
I will change, test and report back.
Your write " Clock not connected", this is also not clear to me how the clock should be connected,
if you look at my code this is all I have: I have a signal 'input clk' and 'always @(posedge clk)', what else do I need to do to
make the compiler understand that this is a clock.
I've not specified in anyway (or have I?) how that 'clk' is connected ... should I and how to do that?
Same confusion about the reset... as this is only meant as test case to gauge the FPGA speed and
the speed of that design I don't know where to connect those at this point and/or how to set them
so that I can get the Fmax out...
wbr Kusti
Your .sdc defines a clock targeting a port named clkx2 that does not exist in your code. Your .qsf shows clocks named clocka and clockb that aren't there either. I'm not sure what's going on here.
If your module was not the top level, and you connected the clock port to '1b1 or 1'b0, then it would be stuck at 1/0.
If this module is your top level, you've already assigned the clk port to a pin, so it will be connected correctly, (and not stuck at 1/0).
The lack of outputs is the problem. The compiler sees your design does nothing useful, and removes all the logic.
--- Quote Start ---
--- Quote End ---
Thanks! All of this is was the information that I could not find from the documentation and what I needed. With the outputs defined it now works a treat! Thanks again!
