I am looking for a model or file which has the value of on-die decoupling capacitors on power pins of the Cyclone V FPGA.
I need this value of capacitor with ESR and ESL so as to correctly model the power pins for Power Integrity analysis of the board.
Thanks in advance.
Perhaps you can try to check on the Power Delivery Network (PDN) tool for Cyclone V Device. You need to download the zip file in the link below and open the spreadsheet. You can go to System_Decap tab and change the device family accordingly.
Aqid
Hi Aqid,
Thank you for this reply.
This is a very good tool to provide idea of PDN.
However, I am specifically looking for some information on decap value connected between BGA ball to die of the IC.
a small decoupling capacitor that we place inside IC package or a parasitic effect due to this
I am looking for IC power pin model to avoid Target impedance issues on frequencies beyond 200MHz
where did you get the idea that Cylone V has internal bypass capacitors? I'm no aware of an Intel document mentioning it. I doubt that there's room for capacitors in BGA package.
I also didn't found any information regarding this on datasheets.
I am mostly looking for any model that can support for actual on die parasitics to mitigate for > 200MHz decoupling of power supply noise in maintaining target impedance in FDTIM analysis.
I also not sure if we have disclosed this information. So far, the only I can provide is the information that was included in the PDN as suggested earlier.
