21613 Discussions
Opencl Licensce Not Found
Sir/Madam,
I a valuating the OpenCL SDK.
When I try to generate emulator version of the hello_world.cl for the default board s5_ref.
I get the below error
aoc: Environment checks are completed successfully
aoc: Selected target board s5_ref
aoc: Running OpenCL Parser
"Could not acquire a valid license for the Altera SDK for OpenCL".
Stack dump:
0. Program arguments:
1. <built-in>:97:1 current parser token 'typedef'
Error: OpenCL parser FAILED.
Refer to hello_wrld/hello_world.log for details.
When I try to generate temporary license in the self-service licensing portal I get error
"No valid products found."
As far as I know you need a license in order to use the OpenCL SDK. You need to buy this license, I don't know anything about this procedure. But using the SDK without a license is not posible.
SPere43
Hello, you find a solution?
