The Stratix V reference manuals says it has 1 SMA out for outputting clock signals. However I would like to use it for outputting a generated signal and sending it down a coaxial cable connected to the SMA. Is this possible? Thanks.- Tags:
- Stratix® V FPGAs
as long as that signal is a digital one-bit signal I think you should be fine, but check the datasheet for slewrates, max current etc.
