21491 Discussions
PCI ExpressのnPERST(pin_perst, PERST#)ピンに4.7k Ohmのpull-up処理は必要ですか?
Gripen
Nooraini_Y_Intel
Hi Gripen,
Which FPGA device are you referring for the nPERST pin? Typically the nPERST pin does not require any 4.7kohm pull up as long it is driven with 3.3V. Please check the respective FPGA Pin Connection Guidelines from the link below:
https://www.intel.com/content/www/us/en/programmable/documentation/lit-dpcg.html
Nooraini
Nooraini_Y_Intel
Hi Gripen,
Nooraini
Gripen
Hi Nooraini,
Thank you for your reply!
I see.
Gripen
