21615 Discussions
PCIe example program on Cyclone 10CX105YU484
RFett
Quartus 19.3 / Intel provides a sample design pcie_ed with a pcie IP connecting to a simple RAM. It runs properly on the Development Kit for Cyclone 10 with a 2 lane gen 2 configuration, 64 bit @ 125MHz.
I have a design based on 10CX105YU484. This board gets properly enumerated using the same design. The provided device driver (altera_pice_win_driver / Altera PCI API Driver) is loaded on my Windows 10 x64, no issue is shown. Running the Interop_software Alt_Test.exe on this board failes. Using my own driver which works with the Dev Kit, shows that only 0xffffffff can be read back. Since the board is enumerated I assume the PCIe IP is partially working. Routing out the Avalon chipselect and write signals to test points do not show any activity. While on the Dev Kit I can properly measure these control signals.
The entire design relies on IPs from Intel, I wonder what I am missing. Any suggestion were to go from here would be very much appreciated.
Harris
Hi RFett,
From your description, it seems the difference is the Quartus design between Dev Kit and your own board? I suggest you check the difference of Address Map in the Qsys designs. Thanks.
BR/Harris
