Hi All,
I'm receiving the following message during PLL compilation: --- Quote Start --- Warning (332056): Node: i_pmu|i_alt_pll|altpll_component|auto_generated|pll1|clk[1] was found missing 1 generated clock that corresponds to a base clock with a period of: 12.500 --- Quote End --- So, what's the problem? Actually the PLL is configured for an input clock of 80MHz and two output clocks 10MHz and 20MHz. I tried to re-create the IP, but received the same results. How to fix it? Thank youLink Copied
This might anwer your question:
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd06092011_472.html
