21602 Discussions
PLL Integer mode vs Fractional modes in PLLs (Cyclone10 transceiver)
amildm
Valued Contributor I
Hi All,
 What's a difference between the Integer mode vs Fractional modes in the transceivers located in Cyclone 10?
How can I set each one of the modes?
Thank you!
Farabi
Hi, sorry to keep you waiting.
Arria 10 FPGA has 2 types of PLL : Fractional and Integer PLL.
Fractional PLL is used when you want to generate a uncommon clock frequencies with fractional numbers such as 6.625Mhz, 3.125Mhz etc clock frequency.
Integer PLL is used when you want to generate a common clock frequencies like 10Mhz, 25Mhz, 125Mhz etc.
how to use and set fractional PLL  is shown in this link:
https://www.intel.com/content/dam/altera-www/global/ja_JP/pdfs/literature/an/an661.pdf
https://www.intel.com/content/www/us/en/docs/programmable/683640/current/implementing-fractional-pll-reconfiguration-33682.html
and this document shows how to calculate Fractional PLL divider value during setup:
https://www.intel.com/content/dam/altera-www/global/en_US/kdb/rd08062012_921/how_fractional_divisor_is_calculated_in_quartus_rev4.pdf
while integer PLL is more straight forward setup, this is the documentation of it :
https://www.intel.com/content/www/us/en/docs/programmable/683359/17-0/altera-phase-locked-loop-ip-core-user-guide.html
If you are new to PLL in Intel FPGA, I would suggest you to get familiar with integer PLL first, then slowly move to Fractional PLL.
best regards,
Farabi
Farabi
I am Farabi who will support you on this request. Let me check the documentation on the integer/fractional PLL setup information.
I will come back when I have the information you requested asap.
regards,
Farabi
amildm
Farabi
best regards,
Farabi
Farabi
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
best regards,
Farabi
