19653 Discussions
PLL is not working in Cylcone V GX (Using Integer PLL)
I have designed Customised board using Cyclone V GX FPGA.
I have fed 25MHz oscillator to non-dedicated clock pin in FPGA.
So i had incorporated ALCLKCTRL.
The design flow 25MHz -> altclkctrl ip -> altpll
In this case pll not locked and therefore no pll output
I have attached schematic file.
Please support.https://alteraforum.com/forum/attachment.php?attachmentid=13877&stc=1
Referring to the 'clock control block (altclkctrl) ip core user guide (https://www.altera.com/en_us/pdfs/literature/ug/ug_altclock.pdf)', only certain signals can drive the inclk port - those being:
--- Quote Start ---
Clock pins, clock outputs from the PLL, and core signals can drive the inclk[] port.
--- Quote End ---
'Ordinary' I/O pins cannot be connected to the ALTCLKCTRL inclk port. So, if your design ran through Quartus successfully, I suspect you've not got things connected up as you think - which may explain why the PLL isn't locking.
Cheers,
Alex
hi alex,
thanks for your reply.
i can't figure out the thing why the pll is not locking.
Have you refered those schematic files attached
Is there anything wrong with schematics attached.
If you must use a non-dedicated clock input pin, have you tried connecting to the PLL first instead of the clock control block? Why are you doing it in this order?
Yes - I looked at the bits of schematics you attached. The problem is, if you want to use a PLL, you're feeding your clock into the wrong pin. The PLL cannot be fed by that pin.
Using an ALTCLKCTRL block won't help as it can't be fed by a clock going into the pin you've chosen. This IP block should be fed by the output of a PLL, not the other way round.
You need to modify the board to either: a) feed the clock into a dedicated clock pin; or b) add a wire loop on your board between an unused I/O pin and a dedicated clock pin and feed your clock signal out of that I/O pin so that the clock is fed to a dedicated clock pin.
Cheers,
Alex
