I am testing PLL output from an old Stratix board. The PLL
has an onboard 80MHz crystal as input clock. However at > 60 MHz, the PLL output is not as square as I wish with ripple and 50mv undershot. At 250MHz, it simply looks like sine wave. The output is observed by a fast scope with 50 ohm termination. Here is my question: is this expected, or something is wrong in my setup that prevent me from geting perfect square at high freq?Link Copied
you did not tell us which scope was used for measurement.
Your scope should have sample rates of at least 2.5 GS/s. What kind of probes did you use ? Be aware that the characteristic impedance of the transmission line used on your PCB is important and how it is connected to your chip.- Mark as New
My scope is tek TDS5034B, sampling rate is 5G/s.
My stratix board have an SMA connector for PLL output, from which I use a SMA-BNC adaptor + BNC cable to the scope. all cable and connector should have a bandwidth well beyond 2GHz. Anybody have monitored your PLL output at high frequency?- Mark as New
what i/o standard and settings are you using?
checking the pin planner, the output pin is 3.3 v LVCMOS.
I suggest to think about some basic signal theory relations. TDS5034 has a bandwidth of 350 MHz. To display a 250 MHz square wave different from a sine, you'll need at least 750 MHz bandwidth to see the 3rd harmonics.
I shall borrow a 750Mhz scope to double check the waveform. meanwhile, how do I get a differential pair from the PLL out?
I changed the IO standard for my PLL output pin to Differential-SSTL2, however quartus II complain about: Error: Can't place enhanced PLL "altpll2:inst23|altpll:altpll_component|pll" in PLL location PLL_5 because I/O cell "Pulsar_Out" (port type EXTCLK of the PLL) is placed in an I/O pin (Pin_B15) which cannot feed port type EXTCLK of PLL location PLL_5 suggestion?- Mark as New
I am looking for an application in which we can take transmitter lock out through SMA connector and feed it to one of the trigger of DSA (Digital Serial Analyzer). So i wanted to know, what is the maximum differential clock frequency that we can get through SMA output port of Stratix V GT board. Can we get some 10+ gigahertz clock output from it. Thanks
