21585 Discussions
POPs & PFOAs declarations
VinceG
Could you please provide POPs & PFOAs declarations for the following products: -
10AX066K4F35E3SGAA
10AX066K4F35E3SG
10AX090N4F40E3SGJZ
10CL120YF780C8G
EP2AGX45DF25C6G
EP2C20F256C8N
EP2C5T144C8N
EP2C8F256C8N
EP3C120F780C8N
EP3C16F256C8N
EP3C16F484C8N
EP3C25F324C8N
EP3C40F780C8N
EP3C55F484C8N
EP3C55F780C8N
EP3C5F256C8N
EP3C80F780C8N
EP4CE115F23xxx
EP4CE15F17C8N
EP4CE40F23C8N
EP4CE55F23C8N
EP4CGX110CF23C8N
EP4CGX150DF27C8N
EP4CGX50CF23C8N
EP4CGX75CF23C8N
I have tried various things including the MMDs but have had no luck.
NazrulNaim_Intel
HI,
Sorry for the delay. Yes these documents can confirm that there are no POP or PFOAs substances present in each device.
Nazrul Naim
NazrulNaim_Intel
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
VinceG
Not a problem, thanks for offering to help
NazrulNaim_Intel
Sorry for the delay. For your request Altera/Intel FPGA does not provide a PFOS/PFOA letter of compliance. All Altera/Intel FPGA products have been free of PFOS/PFOA since 2009.
Really sorry for the inconvenience.
Nazrul Naim
VinceG
Hi Nazrul,
So do you guys have a company wide statement to this effect?
Perhaps a document somewhere on your website that I can download?
Vince
NazrulNaim_Intel
Hello Vince,
Sorry for the delay. For more information regarding this, you can access through the link below.
Link : https://www.intel.com/content/www/us/en/support/programmable/articles/000080881.html
Hope that answers your question.
Nazrul Naim
VinceG
Hi Nazrul Naim,
Sorry mate, that's no help at all.
I found that early on in my search, but I couldn't find any usable Material Declaration Sheet.
Do you have access to these for the product listed earlier?
If so, could you send me PDFS?
Vince
VinceG
Hi Nazrul,
any progress on this at all?
Vince
NazrulNaim_Intel
Hi Vince,
Really sorry for the delay. I'm currently waiting for the internal team to provide the document regarding this. Really sorry for the inconvenience and thank you for your patience.
Nazrul Naim
NazrulNaim_Intel
After discussion with the internal team. For products that have been mentioned, we can refer you to Intel MDDS page https://www.intel.com/content/www/us/en/collections/content-type/mdds.html.
You can download a copy of individual MDDS for each part number to know if there is POPs or PFOAs substances.
Nazrul Naim
VinceG
Hi Nazrul,
As I mentioned earlier, that link takes me to the page, I put in the P/Ns I am interested in, but when I try to download the MMS, all I get is junk.
See below.
What am I doing wrong?
Vince
NazrulNaim_Intel
It seems like an issue for the SML File. Below is the step how to open XML file in Excel
  1. Open a new blank Excel file
  2. Click on Developer tab, then click Import
  3. Select the xml file you want to import, then click Import
  4. Click "OK" on pop-op information, and also "OK" on where to Import data
  5. The table will then be generated, and you will see a lot of "blank" cells due to the long text of the "legalDef" column AK.
  6. I recommend to delete column AK so that the other columns will display better:
Hope that helps you resolve the issue.
Nazrul Naim
VinceG
I have now downloaded all your MMDs for each part and converted them into a readable format.
Are you telling me that these documents can confirm that there are no POP or PFOAs substances present in each device?
Is that correct?
Vince
NazrulNaim_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided, for now I will set this case to Close-Pending.
Nazrul Naim
VinceG
See question above.
Is that correct?
Vince
NazrulNaim_Intel
HI,
Nazrul Naim
VinceG
Thank you Nazrul.
