21602 Discussions
PS(Passive Serial) configuration with third part Microprocessor
KFL
Hi ,
I want to use a  third part Microprocessor to help FPGA(cyclone10 GX) Configurate in PS(Passive Serial) mode,but I  encounter somes problem.
1. Because, MaxV device have PFL IP on it, PFL can  send uncompressed data to FPFA .
 So, If I want to use a  third part Microprocessor send the configuration data, How can I genarate a correct PS configuration data?
 For example,  I have to check device and pin options in quartus, before generateing   PS configuration data . What options I have to enable  ?
2. How should the MCU send data to the FPGA, after programble a correct PS configuration data in Flash ?
NurAiman_M_Intel
You can refer to Cyclone 10 GX handbook for more information;
https://www.intel.com/content/www/us/en/docs/programmable/683775/current/passive-serial-configuration.html
Aiman
KFL
Hi, Aiman
We can know PFL IP help Uncompressed Data , the information come from Figure 13 and 14 in Parallel Flash Loader Intel® FPGA IPUser Guide.
https://www.intel.com/content/www/us/en/docs/programmable/683698/21-1-19-1-0/using-enhanced-bitstream-compression.html
Before genarateing configuration data in .hex , we can do some setting  device and pin options in quartus.
But, I don't have PFL IP. Does the setting have to be adjusting ?
For example, there is a option  called '' Generate compressed bitstreams''  , if I enable it?
NurAiman_M_Intel
If using third party microprocessor, you will need to contact their support team to help for this case. We are not able to provide information about third party.
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
