We are using the PS method to program a Cyclone 10 GX FPGA with the SPI interface of a processor. We are changing the FPGA to a larger device. Is there a command to determine the device type using the PS configuration method? We need to determine the device so that the correct rbf image gets loaded.
Hi Adam,
Thanks for contacting Intel support.
I suppose you are planning to use multiple FPGAs in the design and after detecting the FPGA through PS you have a need to load the correct RBF targeting the device. Please correct my understanding if I am wrong.
Please let us know currently which command you are using to program the device.
Thanks and Regards
Anil
