Could you provide then thermal characteristics, model and package drawing for the 2340A package.
Kevin
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Nazrul Naim
Thank you for reaching out. Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Nazrul Naim
Can you state the OPN for the device that you are using.
Nazrul Naim
Hi Kevin,
OPN is Ordering Part Number. Thank you for clarify the OPN. I will get back to you as soon as have the document that you have reqeusted.
Nazrul Naim
Hi Kevin,
Before sharing the document with you. Would you mind to share the Ordering Part Number to make sure that it is the correct document before sharing to you.
Nazrul Naim
Hi Nazrul,
We are in early stages of design, therefore at this time I do not have the exact OPN we will be using.
Is there a document your could share that has the Ordering Information, I could not find it on the website?
According to the Table 1 in the attachment from the data sheet (ag_datasheet-683301-670300.pdf) the devices AGF 012/014, which we will be using, come in 2 package types R24A & R24B.
Since we have not yet have all of our design requirements completed I would like to have the information for both package types including the thermal modeling data.
Kevin
Below I will attach the example of Ordering Part Number (OPN). This is because our thermal engineer need to know the correct product before providing the document.
Nazrul Naim
Hi Nazrul,
I didn't see any attachment to your reply.
Kevin
Hi Nazrul,
The OPN we are targeting is AGFB012R24C2I3V.
Kevin
Hello Kevin,
Thank you for the clarification. I will get back to you as soon as possible with the solution and document.
Nazrul Naim
Nazrul Naim
