21504 Discussions
Pin Compatibility 5CGXFC7 5CGXFC9
Zarquin
New Contributor II
Dear Customer Service,
are the pins of 5CGXFC7 5CGXFC9 (both F23 package) compatible?
Means can the FPGAs be replaced without schematics redesign?
I tried to find out by pin file compare.
I also know about the pin planner migration option - but it seems that the feature only works for a completed (not for a future) project.
But I'm still not sure about compatibility.
Does anybody know?
Ash_R_Intel
The Quartus Prime software helps to plan migration of the design to a different density device in the same family. You should indicate that to the software early in your design by selecting devices that are available for migration (Assignments -> Device -> Migration Devices). The tool then allocates pins to the design which are common in the migratable device.
More resources below:
https://www.intel.com/content/www/us/en/docs/programmable/683475/19-4/device-migration-planning.html
https://www.intel.com/content/www/us/en/docs/programmable/683143/22-1/migrating-assignments-to-another-target.html
