Community
cancel
Showing results for
Search instead for
Did you mean:
Please confirm that this GND ball is redundant.
I need to rework a board, and the rework is easier (less risky) if I can remove a ball that appears to be a redundant GND ball. All other GND balls are connected to GND.
The device is 10AX048H3F34E2SG, pin AN16 (GND).
BryanH
Hi Bryan,
Sorry but pls on hold your board rework first.
I found a workaround that maybe able to avoid board rework by using FPGA PLL to send clock to clkusr pin directly via some Quartus hacking method.
I will share more detail with you in our forum discussion thread.
dlim
HI Bryan,
I am closing this case as well since you have verified the clkusr workaround in the other case.
dlim
