i am newbie....i wan to write a data like picture into the sdram, and read it out again.....or any related write data and read data from SDRAM....i m using DE2-70.....can anyone share some coding here..or email to (((((lim_zhi_happy_@yahoo.co.uk))))) .....i need help...
And at which part, You're failing to do Your task?
i totally blank....do you have any reference example that can teach me how to write data capture from the CCD into sdram and then read the data again if we press SW and key...at the same time ,data in the sdram used to transfer via RS232 to another DE2-70 board. Means that my 1st de2-70 with a cmos camera capture CCD data and transfer via rs232 to another DE2-70 then store into sdram and display out at LCD. i have around one month to finish my final year project....very appreciate if can help me...can you leave me your email addrs, so that i can send u the example coding i wan to modify.
