Programmable Devices
19675 Discussions
Please tell me about the soft error rate (FIT) of EPCQ4ASI8N and EP2C20F484C8N.
YTagu1
NurAiman_M_Intel
Thank you for contacting Intel Community.
You can find the FIT rate for Altera devices in the Reliability Report. Kindly be noted that the FIT rate for devices within the same family with the same process technology will be very similar and can be used for devices not explicitly listed in the Reliability Report.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rr/rr.pdf
Hope this help! Let me know if you need more information.
Aim
YTagu1
​thank you for your answer.
rr.pdf shows the hardware failure rate.
However, we asked about the soft error rate caused by radiation.
Please confirm.
NurAiman_M_Intel
Please allow me sometime to get the information from our internal team.
Appreciate much on your patience. Thank you.
Aim
YTagu1
​When will the answer be?
We look forward to your response.
Thanking you in advance.
NurAiman_M_Intel
Apologize for the delay in response as the information are still pending from our internal team. Will get back to you once i received the information.
Aim
NurAiman_M_Intel
For Cyclone II device, kindly go to the link below:
https://marketing.altera.com/ts/wwrsc/pg/comp/Document%20Library4/1/SEU/Soft_Errors_Altera_PLDs%20-%...
For EPCQ, i will update once i got the information.
Thank you.
Aim
YTagu1
​I can't seem to access this site.
Please confirm.
NurAiman_M_Intel
I will proceed this conversation in private message.
Aim
YTagu1
​I'm sorry. I do not know.
About "Soft_Errors_Altera_PLDs-2005"
It is not attached to the email.
There is no web search.
NurAiman_M_Intel
I have sent you a new Cyclone II FIT rate document. Please check your private message.
Thank you.
YTagu1
​申し訳ありません。上手く伝わっていないようですので日本語で書きます。
資料が入手できていません。
プライベートメッセージを確認してください。とありますが、プライベートメッセージとは何ですか。
NurAiman_M_Intel
I apologize for the miscommunication. The document i sent is confidential, hence i have sent it through private message. You should receive a notification for private message. Maybe you can try to look at the upright corner if there is any message receive.
Thank you.
YTagu1
Aimさん プライベートメッセージで送信とは、本Eメールのことでしょうか? 本メールには、資料は添付されていませんでした。 宜しくお願いします。 YTagu1
NurAiman_M_Intel
All document regarding Soft error FIT required a CNDA between customer and Intel. Do you have CNDA with Intel? If you do, please provide the CNDA for us to proceed with this request.
Thank you.
Aim
NurAiman_M_Intel
Is there any update on this query in order for me to process this request?
Aim
YTagu1
CNDAが必要な件、了解しました。
本質問に更新はありません。
ありがとうございました。
NurAiman_M_Intel
We apologize as we cannot provide the document without CNDA. Thank you for your understanding. I will proceed to close this case.
Aim
