We are using MAX10 FPGA 10M08DCU324I7G for our application. We are using 3.3V, 2.5V and 1.2V. For all VCCIO banks using 3.3V.
1.2V given only for VCC, VCC_PLL and 2.5V given for VCCA#.
I used Power estimator to calculate the power consumption of GPIO pins(3.3V).
What is the power consumption of the device for 2.5V and 1.2V, since these voltages used only for VCC pins.
In the EPE report page, you get the current consumed by each voltage rail. From that you can calculate the power consumed using the P=VxI formula.
Hope that helps.
