20704 Discussions
Power saving techniques for FPGA
Can someone share experence about power saving in FPGA designs?
I am facing power consumption and heat disipation problems. I tried disabling clocks but that gives very litle diference in power consumption. What else could be done to reduce power consumption?
It is not easy to optimize for power. Perhaps for a start you can check against the EPE to have an idea of static vs dynamic power distribution - just to estimate the potential reduction that can be done on the dynamic side. For static, if you device supports it, turn on the PowerPlay power optimization to normal/extra effort. Then, on the programmable power technology optimization, select the one that fits your design requirement.
--- Quote Start ---
--- Quote End ---
Can you provide any hint on where to start with EPE? I have never used it.
--- Quote Start ---
--- Quote End ---
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_epe.pdf
Use Processing->PowerPlay Power Analyzer Tool to write a EPE file, which you then import to the spreadsheet so you can play with "what if" scenarios.
