Thank you for contacting Intel Community.
For your information, there is no changes in term of tray size for now and if there is any changes in future tray size, there will be an update from us.
For packaging datasheet, you may refer to the link below:
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-index/lit-pkg.html
Thank you.
Aim
Hi, i have review the packaging data sheet, but unable to find any tray size information. can you please assist me on this? thanks
Apologize for the misunderstanding as i thought you were requesting for packaging datasheet.
For tray size, you can refer to AN71 below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an071.pdf
10M08DAU324I7G is a UBGA, and the tray size is 15x15mm.
Hope this help.
Aim
how about the column qty? because previously we received 7X18 (15mmX15mm) but now we received 7X17 (15mmX15mm). can you help me to confirm?
By column, did you mean the number of unit that a tray can have? If it so, then it can have 119 unit.
Please correct me if i misunderstood for this.
Thank you.
Aiman
Hi, can i have the vertical and horizontal qty?
like vertical 7 column and horizontal 17 column?
thanks
I will need to request the information from our internal team. I will get back to you next week once i got the findings.
Aim
Hi Aiman, any update regarding this?
We are still in the progress of getting the information. Apologize for the inconveniences and thank you for your patience.
Aim
Hi Jess,
I have the requested information. Please check your private message for the attachment.
Kindly inform me if there is any further information required.
Aim
