Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Problem DDR2 bandwidth
I'm working on the cyclone IV GX dev board and using DDR2 SDRAM for stocking images coming from a camera.
In the documentation of the dev board, the maximum theoretical bandwidth of the DDR2 is 10.6Gbps. But in my case, i have just 200Mbps when i read from DDR2. this is a problem because i have under 10ms to process two images (752x480).
Of course, I use burst.
I'm using the "DDR2 SDRAM-controller with ALTMEMPHY" to control the DDR2.
I have posted my SDRAM-controller configuration to help you.
Does anyone know why the bandwidth is very bad?
hallodu
