I use FIR Complier v9.1 to generate a FIR filter. However, it does not generate the netlist file (<variation name>_st.v).
When I do synthsis, it shows the error "Error: Node instance "fircore" instantiates undefined entity "filter_st" File". There is no problem to use MegaWizard to generate other IP, such as multiplier or CIC. Any help are very appreciated.Link Copied
I have the same issue and cannot find a workaround/resolution.
Copied this from the other thread...
Found the solution: download and install/repair Microsoft Visual C++ 2008 SP1 Redistributable Package. Also, make sure the latest version of Java is installed. http://www.microsoft.com/downloads/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&displaylang=en
