Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Problem in using DDR
Hello everyone,
I have a problem in using ddr on Cyclone III starter kit.When I have compiled the design,it failed at the fitter with this error notification.
Error: can't place pin mem_dqs[1] to location T8.
can't place VREF pin T6 (VREFGROUP_B3_N0) for pin mem_dqs[1] of type bidirectional with SSTL-2 Class I / o standard at location t8.
can anyone help me please?
Highlighted
Re: Problem in using DDR
I face this problem before. You have to do some setting because there is too much bidir pins for 1 Vref.:)
1st :
Assigment-Device-Device and Pins option-Dual purpose pins(set all value to: use as regular I/O accept for DClock&nCEO.
2nd :
Assigment-Assigment Editor- Change all DQ,DQS and DM pins to (Output Enable Group). For the Value column, set any number same for those pins.
eg: DQ[0]->Output Enable Group->123456(Value)
3rd :
Assigment-Pins(Change IO standard for all DDR related pins to SSTL-2 Class I.)
You now are able to compile without any fail hopefully. I face this before and want to help you.:o
Thank you:
Shahril
Highlighted
You are welcome. Just want to ask, is it currently you also work on DDR memory? It will be great if we can work together. I just want to store a series of data inside DDR SDRAM. Is it you already start to do the software part? 😮
